disable clear-flow
disable clear-flow
Description
Disable the CLEAR-Flow agent.
Syntax Description
Default
CLEAR-Flow is disabled by default.
Usage Guidelines
When the CLEAR-Flow agent is disabled, sampling stops and the and all rules are left in the current state. It will not reset actions that were taken while CLEAR-Flow was enabled.
The following example disables CLEAR-Flow on the switch:
disable clear-flow
This command was first available in ExtremeXOS 11.1.
Platform Availability
